adding relationship class
2020
05-07-2014 10:27 AM
DorotaStanczak
Hello, my problem is probably easy to solve. But I don't know how and I can't find solution. It is about adding relationship class to the Map. I created relationship class between two layers in geodatabase directly (I tried also creating relationship class in feature class dataset). Everything is created correctly (cardinality - I tried one-to-one and one-to-many, primary keys etc.). I can see relationship class in Catalog tree but I can't add relationship class to the Map. I get "Could not add specified data object to the map". How can I handle this?
I think that everything is ok with geodatabase since I can create relationship class (many-to-many) between a layer and non-spatial table and add it to the View.
The layers for the problematic relationship class are empty - since this is only template for database, but that was not a problem in creating relationship class with non spatial table.
I would really appreciate some advice.
Cheers,
Dorota
JoeBorgione
Don't try to add the relationship class; add the two feature classes or what ever is related in the relationship class and it (the relationship class) comes with them.
That should just about do it....
DorotaStanczak
Thanks Joe 🙂 I knew the answer is easy but I didn't think it is as easy 😉 I checked and it works. The relationship itself is not added to the Table of Contents, but when I identify a feature in one layer I can see that it is related to a different layer 🙂
JoeBorgione
Same thing happened to me; struggled with the exact same thing you describe, and then had an "ah ha" moment....
