adding large number of vertices to the perimeter of a circle?
1282
01-10-2012 08:49 AM
AnnaBuchheit
Hi
Does anyone know if there is a fairly simple solution to adding points along the perimeter of a circle?  I would like to add a large number of points, distributed equally along the perimeter of a circle but I am not sure if there is a tool that will generate multiple points at one time.
Any help would be appreciated!
Thanks!
NelsonDe_Miranda
Euloki,
You want to use the "Densify" geoprocessing tool.
Information about it can be found here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001v00000003000000.htm
Note: you may want to do a test on some sample data since it does modify your input data.
Cheers,
Nelson
WeifengHe
Using Advanced editing tool Generalize to insert multiple vertices into the circle.  Then, in ArcToolbox, using Feature Vertices To Points to create a feature class containing those points of the input generalized circle.
