I haven't specifically heard about it, but than I also didn't dig into it to find out. Jake Skinner can most likely tell you...
How about the 10.2? is such tool (adding features to an existing replica) built �?? in on the core?
Jamal, there are cases where the Geoprocessing Tools and corresponding Wizards or dialogs in the user interface of ArcGIS don't entirely match.This seems to be one of those cases. It means you will need to use the Create Replica Wizard (or ArcObjects programming) to do the job.It would be nice if things always corresponded for the full 100%, but I can appreciate there might be cases where it is difficult to implement from a technical point of view.
I wanted to use the �??create replica�?� as geoprocessing tool but couldn�??t figure out which option is equivalent to �??Select Register existing data only�?�
Hi Jamal,Take a look at the following KB article for the steps to do this using Desktop:http://support.esri.com/en/knowledgebase/techarticles/detail/35679
Signed in members can post, follow updates, and more. New here? Register a free account.
