popup distance showing distance vertex has moved
709
03-01-2012 06:31 AM
Status: Closed
MilesLoretta
As I edit vertices, I usually know how far I want to move it due to consistent distances and measurements.  I'd like to see a distance-moved popup bubble showing how far I've moved the vertex.  You could move the vertex, release the selection and then grab it and move, knowing the straight distance right then.  I work on measuring property along a rail line and know the distance from track center.  Could save a ton of time when you know how far you need to move a vertex.  Kinda like integrating the Measure tool into the editing features.
Hopefully others will agree with this idea.
2 Comments
by Anonymous User
You can already move an individual vertex by a discrete x,y amount or to an absolute x,y position. Are you after a bearing/distance constraint for moving vertices much like the constraint you can set on the next segment of a sketch?
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the ArcGIS Pro Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
https://community.esri.com/t5/arcgis-pro-ideas/popup-distance-showing-distance-vertex-has-moved/idi-...
