why do my popups have same settings but different look?
3036
13
01-19-2017 02:50 PM
SuzanneLuhr
 VERSUS
These are popups in my web map. I want to get rid of the line and extra space in the first popup. There is nothing different about how I made each popup - each has only the title and photo link. Why do they present differently? Image size? Image dimensions?
Tags (1)
AdrianWelsh
MVP Honored Contributor
Suzanne,
Is there a way to share your web map link? The Devil's Tower popup looks like it doesn't have a title in the pop-up title area:
RupertEssinger
Esri Alum
Hi Suzanne
Also if this is Story Map related can you include the URL to the app. If not Story Maps related then the more general ArcGIS Online  space in Geonet may be a better bet (although we are lucky to have Adrian Welsh‌ active in the Story Maps space
Rupert
SuzanneLuhr
It is a story map. We only have it saved within our organization, so is there a way to share it with you without going public?
AdrianWelsh
Suzanne,
You can make a group in ArcGIS Online and invite certain users to that group (and allow that group to have access to your map/app).
What is a group?—ArcGIS Online Help | ArcGIS
RupertEssinger
Esri Alum
Hi Suzanne
Can you let us know which of the eight Story Map apps you are using?
Rupert
SuzanneLuhr
This is in Map Series. I will set up a Group soon. Thanks!
SuzanneLuhr
Hi Rupert,
I just realized Adrian is not part of ESRI. So I created a group and invited you both. The Geo-tourism Series  map is what I'm working with, but the Nearby Sites map is embedded in the series. It's the popups in the series that are causing me heartburn. The only thing I can think of is that the photos are not the same format, causing the line under some titles and not others. And more space.
Thanks!Suzanne
To: Suzanne Luhr <suz_wyo@yahoo.com>
Sent: Friday, January 20, 2017 10:15 AM
Subject: Re: - Re: why do my popups have same settings but different look?
#yiv8477407132 * #yiv8477407132 a #yiv8477407132 body {font-family:Helvetica, Arial, sans-serif;}#yiv8477407132 #yiv8477407132 h1, #yiv8477407132 h2, #yiv8477407132 h3, #yiv8477407132 h4, #yiv8477407132 h5, #yiv8477407132 h6, #yiv8477407132 p, #yiv8477407132 hr {}#yiv8477407132 .yiv8477407132button td {}
GeoNet
reply from Rupert Essinger in Story Maps - View the full discussionHi SuzanneCan you let us know which of the eight Story Map apps you are using?   Rupert
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in Story Maps by email or at GeoNet
Following Re: why do my popups have same settings but different look? in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
AdrianWelsh
Haha, thanks Rupert.    I troll here and there...
SuzanneLuhr
Rupert, Adrian, I have made a group and invited you both. I'm learning!
