Using two story map templates together
2453
12-05-2013 10:18 AM
AnnaSan
I would like to know if it would be possible to use two story map styles in the same story map.
What I want is a multiple tab map ( like using the 'Storytelling Text and Legend' template), and having the ability to turn layers on or off in one of the tabs/map (similar to this story map: http://placematters.net/ESRImap/index.html )
Is this possible? or will it just be very complicated to configure?
StephenSylvia
While this is possible, you will need a basic to intermediate knowledge of JavaScript. Adding this type of function to the template is not a simple configuration but requires additions to the source code.
