upload picasa photos in story map tour template
4737
7
05-21-2015 02:27 PM
braulioubilla
I have my photos in picasa.They have  latitud and longitude (I can see the metadata and also i see the photo in the right place in the picasa map) but when i want to upload the photos in the esri template i have located = 0 !!
tks!!
GregoryL_Azou
I just tested on my account and works well. It must be a settings...
In the Google+ UI, when you edit the album, is the following checkbox present and enabled?
In the older picasa UI, in the sharing dialog, it that checkbox present and enabled?
GregoryL_Azou
braulioubilla
tks a lot!! a simply checkbox!!
2015-05-21 18:40 GMT-03:00 Gregory L'Azou <geonet@esri.com>:
GeoNet
<http://jiveon.jivesoftware.com/mpss/c/iAA/PDcDAA/t.1n7/N-tcMkoYTfqxWeh5mnmC2w/h0/WXYIqorVIGQuIDJ2G2ju5AEeIPykSY57g2VIWA8pAkF2-2BlveMrdQT1t2nJlEgcli> upload
reply from Gregory L'Azou
<http://jiveon.jivesoftware.com/mpss/c/iAA/PDcDAA/t.1n7/N-tcMkoYTfqxWeh5mnmC2w/h1/WXYIqorVIGQuIDJ2G2ju5AJJ3r09ASNAhHKWP9Td2hQhqEpx1IMLV5dyN8o1zDaBPfYByvJFICLO5XXo-2Bym-2FdeFEtECy9MK0w4-2B-2BJxzdUpQ-3D>
in Story Maps - View the full discussion
<http://jiveon.jivesoftware.com/mpss/c/iAA/PDcDAA/t.1n7/N-tcMkoYTfqxWeh5mnmC2w/h2/WXYIqorVIGQuIDJ2G2ju5BgYGKlxCJXzUFxsSjPkR7iGTw-2Bf1UOqyd0Z2gtoXjAXqRExOOpLr-2BnY-2BjUW8vRKZM9wk1kpV62HMKo5-2FDjkc7E-3D>
braulioubilla
perhaps you can help me with another question.
can I use a webmap created by me as map base in the story map tour, when
you use the template
you can not select one you have to use one by default
tks a lot !!
2015-05-21 18:52 GMT-03:00 Braulio Ubilla <bubilla@equipos.com.uy>:
GeoNet
GregoryL_Azou
You are welcome.
Yes you can do that in Map Tour. Every Tour has an associated web map that you supply or is created for you behind the scenes. Map Tour Builder is limited to a finite set of basemap but if you go to "My Content" in ArcGIS Online, find the webmap (will have the same name than the app) and use the Map Viewer to edit the basemap you can use any basemap that you want.
braulioubilla
gregory, sorry but i dont understand your explanation, perhaps i didnt
explain well what i need (Im not english native so my english is not so
good).
I have my own map (with my shapes) and I would like to create the story
map tour over my map.
or create the story map tour and then load my own map (in others template
you can choose your map from the template)
tks again!
2015-05-21 19:01 GMT-03:00 Gregory L'Azou <geonet@esri.com>:
GeoNet
<http://jiveon.jivesoftware.com/mpss/c/rAA/PDcDAA/t.1n7/GzLuwRD2TXe8LpY02Hy8Rw/h0/WXYIqorVIGQuIDJ2G2ju5AEeIPykSY57g2VIWA8pAkF2-2BlveMrdQT1t2nJlEgcli> upload
<http://jiveon.jivesoftware.com/mpss/c/rAA/PDcDAA/t.1n7/GzLuwRD2TXe8LpY02Hy8Rw/h1/WXYIqorVIGQuIDJ2G2ju5AJJ3r09ASNAhHKWP9Td2hQhqEpx1IMLV5dyN8o1zDaBPfYByvJFICLO5XXo-2Bym-2FdeFEtECy9MK0w4-2B-2BJxzdUpQ-3D>
<http://jiveon.jivesoftware.com/mpss/c/rAA/PDcDAA/t.1n7/GzLuwRD2TXe8LpY02Hy8Rw/h2/WXYIqorVIGQuIDJ2G2ju5BgYGKlxCJXzUFxsSjPkR7jSgPUsVO-2Bk0p91SsQCYOfIN4-2BkQnovXvn-2BbnsEgxgNYb7VRe-2FC-2BjedFHR61Lm2UvE-3D>
braulioubilla
ready, first i have to create my app and then upload my shapes over the map
tks a lot
2015-05-21 19:37 GMT-03:00 Braulio Ubilla <bubilla@equipos.com.uy>:
good).
tks again!
GeoNet
GregoryL_Azou
No worries
Yes that's what I meant because I thought you only wanted to change the base layer of your map.
You can create an app from an existing web map.
Open your web map in Map Viewer (like I described earlier) and click the share button, then click make a web application then select Map Tour. See the following documentation for reference Create apps from maps—ArcGIS Online Help | ArcGIS
