Story Maps & Oracle?
2206
12-03-2015 01:26 PM
JohnWhitfield
Instead of adding a CSV file on ArcGIS Online, can one use a table in a Oracle database of the same format residing on a local server. If so, how would it be linked since there is no URL, or does it have to be manually zipped and added? or what options.
Thanks in advance for thoughts on this
regards
GregoryL_Azou
Regular Contributor II
There is no option to directly use a database in StoryMaps. StoryMaps use webmap which as far as I know cannot directly exploit database either, you need to create a layer using ArcGIS Server or upload your data to ArcGIS online. To upload your data ton Online, you could use ArcMap or ArcGIS Pro that I think can directly connect to your Oracle database. Or if you can export as a CSV that's also an option.
The following links may help you more:
Oracle database requirements for ArcGIS Pro 1.1—ArcGIS Pro | ArcGIS for Desktop
Connect to Oracle from ArcGIS—Help | ArcGIS for Desktop
CSV, TXT, and GPX files—ArcGIS Online Help | ArcGIS
GregoryL_Azou
JohnWhitfield
Thank you for your response!
