Story Map Tour edit point location
1858
03-06-2017 03:11 AM
AliBarakat
hello,
i created a story map tour and everything is great.
on one machine i am able to drag and move points (using chrome 47).
but on another machine i am not able to drag the points (using chrome 56)
is there any limitation with the browsers?
thanks
Tags (1)
StephenSylvia
I just looked through our code and it appears the change in Chrome happened in December 2016 and we were able to roll out a fix in the December release of ArcGIS Online. ArcGIS Portal releases occur a couple month after their ArcGIS counterparts and will include previous version's template updates. The fix will automatically be applied the next time your administrator updates your version of Portal.
Alternatively, if you need the fix immediately, you can ask your portal administrator replace the Map Tour template files with the most recent version from our github account: http://links.esri.com/storymaps/map_tour_template_zip
StephenSylvia
Did you download and host the version of the map tour on your own server? There was a change in Chrome a few months ago that required us to change our drag-and-drop code. If you did, you will just need to download the latest version of the code to get a fix.
AliBarakat
No i just used the one from the portal (add item, create app using template and story map)
StephenSylvia
