Hi;
We have created a nice portal using Portal for ArcGIS also generated lots of web apps and maps. Everything is working very well.
While we are exploring the capabilities of the Portal for ArcGIS we discovered the Story Map Journal template which is the most popular template of the Portal for ArcGIS. But we faced a problem about generating a Story Map Journal and other templates which are coming with the ArcGIS 10.3 version.
In the Configurable Apps tab we can't see the Story Map Journal and other 10.3 templates, we see some templates from 10.2 version and some of them is not working stable.
Anybody know what is the reason of this problem? What can we do to see or import the up-to-date templates of the Portal for ArcGIS 10.3 version.
Thank you so much for your helps.
