Story Map does not save the extent when scrolling
628
02-27-2020 11:44 AM
AlbertGarcia4
Help!! I created a Story Map (old version, before the story maps update) a while ago for a supplemental reading program. The first map was set to scale closer as you scroll down, displaying the country, province, and city of focus as you move through. Now the scale keeps resetting to a different area on one and the wrong location on the other. I keep "managing" the map to where it's supposed to be but it doesn't save. Anyone else have this problem? I've tried both enabling and disabling the interaction, same thing.
Here's the link - the first map is supposed to be a full scale zoom of the world, then as you move it used to move down to the local scale. I don't know what's changed, I've tried resetting the location but it keeps popping back to the wrong one!
Thanks in advance for any help you can give.
A. Garcia
https://arcg.is/10DCvH
michael_vetter
You might have already tried this, but it might be easier if you create three separate web maps at the various scales then set a transition to the correct web map as the user scrolls the story down.
