Story Map Custom Popups
2468
02-02-2016 04:06 PM
JamieSheehan
Is there any way to force custom pop-ups to 'pop' up at the location selected when chosen?
If not, could the developers consider adding this please...
For linear and polygon features, when you select and save a custom popup you can do it at any location along or around the feature, ensuring it does not cover other surrounding features. When you play the story map live, it reverts to the centroid of the polygon or line - for many long line (or irregular polygon) features, the 'centroid' is no-where near the actual line...
GregoryL_Azou
Thanks for the feedback, there is no way to do that, it's a bug in the application (some of our other applications like Map Series behave correctly), I am going to look into this. I opened an issue on the development tracker to keep track of it Main Stage popup configuration open on the popup at feature centroid instead of where author clicked...
GregoryL_Azou
