Shortlist image links - no link = no display
1210
02-08-2017 09:46 PM
GeorgieCassar
Hello,
I have created a shortlist app from a point file and allocated fields from the point file to contain links for the thumbnail and main image.
If some of those link fields happen to be empty, then the item does not display at all on the map or the thumbnail display.
Is this by design ?
What if I wanted to manually add an image to one of the features from my point layer using the configuration environment ?  (Main image or thumbnail ?)
Tags (1)
MarkCooney
Hi Georgie,
It is by design that places will not show up in the VIEWER for Shortlist if they lack a photo, name, or location.  These places are loaded in the BUILDER for Shortlist which will allow you to add/edit any of these attributes.
-Mark
MarkCooney
Hi Georgie,
-Mark
