Hi Gregory,Â
I am using jekyll and gitpages. I have the maptour running successfully on my local server with 99 markers. I want to add more than 99 markers though.
I've added in the extended marker set. I don't understand when to add in the "&edit" though because through the local host I never actually load the appid in to the browser. All I see is http://127.0.0.1:4000/.Â
I've only added the appid through index.html. When I put appid: "64f4a989a44445fe85788a6a27282ece&edit", on line 47, and then try to load it on the local server, I get "An error occurred Fatal error: The story cannot be loaded."
When do I add "&edit" in?
In case it helps, this is my repo- https://github.com/elpinguinodev/maptour_user .
Story map apps that have been downloaded have two ways to configure an app:
When configuring the app through the index.html file as you have done, you should only use the alphanumeric id and not the "&edit."
The builder mode of the app is always opened via the query parameter. In your case, to load the normal app, open:Â https://elpinguinodev.github.io/maptour_user/. Or to open the builder mode, use:Â https://elpinguinodev.github.io/maptour_user/?edit.
Here's a brief introduction to query strings as part of the URL:Â URL - Marketing GlossaryÂ
Hi Stephen,
Thank you for explaining that. I've updated the map now!
