New Map Tour is breaking my Web Maps!
2647
12-11-2013 04:31 PM
SeanBennell
Heads UP! If you use Bing as a base in your Web Map then build a Map Tour using that Web Map and save the tour, your Web Map will break. I  found this out the hard way but then went back and did a few tests and here is what I found.
When I make a Web Map using Bing Maps Roads as a base, the Map Contents section of Details shows this url reference:
http://www.esri.com/software/arcgis/arcgisonline/bing-maps.html
When I use this Web Map in a Map Tour and save the tour, the url reference for the Bing Maps Roads base changes to this and the map will no longer open.
http://dev.virtualearth.net/REST/v1
Oddly this only seems to happen when saving from the Map Tour (I resaved the Web Map in the Map Viewer and everything was fine).
I have Map Tours that currently use Bing as a base and I'm afraid the next time I update them and hit save, I will break my Web Maps which would obviously be very frustrating.
Anyone else experience this?
GregoryL_Azou
Sorry for inconvenience, the issue will be fixed Friday night.
SeanBennell
Great news. Thanks Gregory!
GregoryL_Azou
The fix has been delayed to at least Monday night PST.
I will let you know here when it's good so that you don't break more app.
GregoryL_Azou
The issue is now fixed. Thanks for reporting.
