When I use arcgis online assistant to make a backup copy of a story map, it copies over all content apart from photos that you have uploaded. However when you go to edit the copied story map it doesn't allow you to add photos back in. I know you can use some other tools using a pro version but it seems rather costly. Will there by chance be new functionality added at some time in the future to make up backup copy of your storymaps within ArcGIS online? Also I am just wondering if you have an approximate timeframe of when you may release the new shortlist/map tour template you are working on (i.e. September this year or sometime next year?) Thanks again Sally
