Limit accordion popups to only the current time extent
3325
10-13-2014 08:23 AM
KevinHibma
Is there a setting that can be changed on the accordion map to make popups honor time enabled layers? A map in the arcgis.com viewer only provides a popup(s) for the current time extent. The story map template provides all popup values even though a time extent exists. I then have to arrow through values that dont satisfy the current time extent.
StephenSylvia
This is fixed when the app is updated to v3.11 of the JavaScript API. I just updated the source code to use this version of the API.
StephenSylvia
The app should provide the same popup experience as you see in the ArcGIS Online map viewer. Sometimes there are slight differences in the JavaScript API and the code behind ArcGIS Online. Can you share a link to you app and the links to your web maps so we can investigate?
StephenSylvia
KevinHibma
Thanks - works great.
