In the story map Cascade builder, is there a way to scroll the outline pane?
1197
02-27-2017 04:08 PM
AliciaFreeman
It's frustrating to have to scroll through the entire story map when making additions or reworking the order. I'm also not able to see any of the slides on the outline pane past the 4th one, since I cannot scroll to them.
AliciaFreeman
Hi Owen,
Thank you for your response. I just opened it up in Google Chrome and saw the scroll bar there. The computer that I have been using to make this story map does not have chrome, and I do not intend to install it for security reasons. I was using Microsoft Edge up to this point and was able to use most of the application in this browser.
However, I will use the computer with Chrome installed to finish my project. I had not seen that it was only supported in Safari and Chrome until today.
Thank you for your help,
-Alicia
MeganMcClain
To scroll through mine I used the left side under save - clicked on what section I wanted to work on. I also have it broken up into sections and click at the top to which main section as well. Are they broken into sections?
OwenGeo
Esri Notable Contributor
Alicia,
Sorry you are having trouble navigating your story in the Cascade builder. Can you please let me know what browser are you using?
In the meantime, please try building your story in Chrome or Safari and let me know if you are able to scroll the overview panel.
Owen
Owen Evans
AliciaFreeman
Hi Owen,
-Alicia
