I have posted a story map temporarily for testing using Pancake.io and Dropbox to host the files. The link is http://wuvstory.pancakeapps.com/. Several icons do not display properly: twitter, facebook, bitly, Toggle description, Toggle legend, Minimize list, the “x” symbol to remove a search term, and the filter funnel icon. I assume I may need to edit the index.html file to modify file paths, or maybe the icons are not present in the files I copied to Dropbox. Can you advise? Thanks!
Solved! Go to Solution.
Hmm, it looks like this could be an incompatibility with Pancake.io. It looks like Pancake (Dropbox Basic Usage - Pancake Docs) and font files are not included. When I load the font file directly from dropbox, it appears to display the icons correctly. However, when using the pancake URL, the icons get converted back to the normal alphanumeric characters.
