I've been attempting to link to an Occipital 360 panorama on a Cascade Story Map, but for whatever reason, it won't load! Any ideas on why?
3182
06-28-2016 04:05 PM
PierreGerard
Here's the link to an example 360 pano: http://360.io/eNgaUr
OwenGeo
Esri Notable Contributor
Hi Pierre,
I was able to add it to an immersive and sequential section (it isn't supported for the cover).
My suspicion is that it's not working for you because of a mixed content situation. If your Cascade builder is being accessed over https then you have to use https for any content you add to your story. Try using https://360.io/eNgaUr
Owen
Owen Evans
AdrianWelsh
MVP Honored Contributor
Pierre,
I am guessing that that type of format is not supported in the cascade story map. How are you trying to link it? If it's just a hyperlink to the panoramic image itself, then it can be a linked url in the popup. Either way, I'm curious to hear what others say about this.
OwenGeo
Hi Pierre,
Owen
Owen Evans
AdrianWelsh
Owen,
Did you basically just add this as a website? Or is there something special you need to do with these kind of panoramic images?
PierreGerard
Hey Owen, yup, adding the "https://" prefix to the website address did the trick, and I now have the website embedded in the Story Map as you have it in your screencap. I am using https, and this was a mixed content issue. Thanks!
