How to change symbology/markers on Story Map - Map Tour?
4556
07-14-2015 10:08 AM
EmilyLee
Hello GeoNet Community,
I'm trying to change the symbology/marker on Story Map, more specifically, on the Map Tour template.  I downloaded the "configurable app" version (not the developer/GitHub version).
Within its resources folder, there is the markers folder that contain all the default markers.
I replaced my own markers for all of them.
But after I deployed it in the web server, I still got the default markers instead.
I tried to look into its app\maptour-config.js file, but I'm not sure where else to possibly go to update the codes for markers.
I thought it would be something simple, but maybe I do need to download the developer/GitHut version instead for changing the markers?
Any suggestions is greatly appreciated!
Thank you!!
Emily
JeffWard
Honored Contributor
You could see what the name of the marker is that the app currently uses, then search the files for that image file and replace it with yours.
Jeff Ward
Summit County, Utah
JeffWard
Honored Contributor
Jeff Ward
Summit County, Utah
EmilyLee
Thank you for your reply, Jeff.
