how to add the locate button to story map
1251
03-06-2017 08:22 AM
MarkFleming
Thanks, Owen;
I understand that sharing a link to my Story Map using an address starting with HTTPS will allow my map readers to utilize the locate button. I don't understand how I control the protocol for sharing a link to my Story Map. Is it as simple as typing in HTTPS instead of HTTP, before sharing, or is it a setting withing the Story Map app?
Mark
Mark — ArcGIS Online supports http and https connections, and you control what protocol is used when you share the link to your story. So just share the story with an https link and readers will be able to use the locate button. If you have any follow-up questions, it would be great if you could please post them to the Story Maps GeoNet space: https://community.esri.com/community/gis/web-gis/storymaps
StephenSylvia
Yes, all you have to do is make sure the URL starts with https not http. If it is http, just add an "s" after the "p." You should see a green lock in the URL bar if you are using the correct URL. Once you have the app loaded over https, you can share the URL or click any of the share buttons in the app.
StephenSylvia
MarkFleming
Under "My Content" click on the Web Mapping Application for your Story Map. Click on the settings tab for that Story Map. Scroll down to URL. Change the address to https:// and hit Save.
