How can you enter in a new line in the narrative section of the Story Map Cascade without it creating a new section?
1721
01-23-2017 12:26 PM
AdamCarr1
You can't even make it how I would want it here, but kinda like this:
"Make it
look like this, but
without the space in
between the lines."
rather than like this:
"Not like this
with the large
gaps making it seem
like a new section."
Any thoughts on how to do this or fix the issue?
Thank you.
OwenGeo
Esri Notable Contributor
Adam,
Unfortunately, we don't support that style of text entry at the moment. Could you provide a bit more information about how you'd use text formatted in that way in your story so I can understand your use case and requirements? You also may want to submit your idea to ArcGIS Ideas so that others can upvote it if they would find it useful.
You could try using the H1 or H2 heading formats in situations where you only have a few words on each line. There will still be spaces between the lines, but it may look better with the larger text size.
Owen
Owen Evans
OwenGeo
Adam,
Owen
Owen Evans
