disordered pictures in web mapping application with existing map tour layer
983
01-21-2014 11:43 PM
WillemDerickx
Making a new web mapping  application of an existing maptour layer results in a completely disordered application. That is:
the pictures in the caroussel do not line up with the pop up numbers of the original application.
The table in the map tour layer hasn't been changed.
How is this possible?
GregoryL_Azou
I'm not exactly sure what you mean.
If this doesn't help, please send me a link to your app or your appid.
If in your original tour you have reordered your points using the Organize dialog, the data in your layer won't in fact be reorganized. Instead the order configuration is stored at the application level. So by design if you create a new application with the same webmap, your data won't be organized the same way than in your original application, you have to redo the work a second time.
If you have dropped the layer in your webmap and added a new one, the data can become messy. In the Organize dialog, using the bottom right button "Reset order and hidden points" should do the trick.
