Custom Basemap for Shortlist App
1062
03-07-2014 10:02 AM
LukeFawcett
How can I use a custom basemap for the Shortlist App?
I can add one into the ArcGIS Online map (when I add my Shortlist Points), but the Index.html will not load with the custom basemap.
Thanks!
Luke
LukeFawcett
Answer (from ESRI Tech Support):  Using a basemap that has a projection other than Web Mercator Auxiliary Sphere causes the shortlist application to continuously spin and not load.
BUG:  NIM099707
They're working on a fix.  Alternate Solution - publish the basemap service in Web Mercator Auxiliary Sphere.  (This worked like a charm).
Luke
RupertEssinger
Esri Alum
Hi Luke
What type of custom basemap do you want to use? It should just work as long as your custom basemap is publicly accessible.
Rupert
LukeFawcett
BUG:  NIM099707
Luke
RupertEssinger
Esri Alum
Hi Luke
Sorry about the issue and I should have thought about that projection point
