Crowdsource: add ability to get XY from photo metadata, and recognize Lat/Long data input in location field
1874
08-03-2016 11:08 AM
RobBlash
  • What steps did you follow to cause the issue?
    • Uploaded a new photo from and Android device using google account authorization
  • What was the expected result?
    • I would expect the photo location to be imported from the photo metadata
  • What was the result you observed?
    • The app asks the user to input the location. After entering the lat/long from the photo metadata an error message is shown stating "The location you searched for cannot be found...." A place name or address are the only acceptable location inputs.
  • Provide a link to your story (be sure to share it publicly)
Tags (1)
OwenGeo
Esri Notable Contributor
Robert,
I just noticed you also asked about adding coordinates. Our geocoder recognizes coordinates in the order longitude then latitude, so try reversing the coordinate values.
We are looking to improve that experience in the next release by offering contributors that enter coordinates a suggestion to choose the location with the coordinate values swapped.
Owen
Owen Evans
OwenGeo
Hi Robert,
Thanks for taking the time to submit feedback. Crowdsource will most likely read photo geotags at the next release in September.
Owen
Owen Evans
OwenGeo
Robert,
Owen
Owen Evans
RobBlash
Thanks for following up, I'll give it a try.
