Creating additional icons - e.g. for Playlist template
7332
21
11-15-2013 05:25 AM
MarkBrickley
Are there directions somewhere for making numbered icons? Our "tree memorial" project is being done by college students for a local town. My earlier comment (on the Playlist template page) was that we probably need 500 points, but the Playlist template is limited to 99. I do appreciate the new revision having a search capability, but the real advantage of the Playlist is the ability of people to browse the list (left panel) of people with trees named after them and see a photo. Clicking that item brings you to the tree's location and a popup with more details of that person. The students are computer savvy, so they can build icons if there is a way to do that AND the code will allow us to change the upper limit to 500 or so. If making icons is possible, how do we do that?   Is it necessary to use numbered icons?  Can't we just use the same symbol (a point) for every tree on our map?  Thanks in advance!
JulieK
Hello,
Both the links don't work for some reason. Is the zip folder still available for download ? It says the site is down .
Julie
StephenSylvia
Looks like this one still works: http://links.esri.com/storymaps/numbered_marker_symbols.
