Collapsible side description panel in bulleted map
5854
11
01-08-2015 06:39 AM
Arthurgov
In the Bulleted map, is there a way to modify the code to have a collapsible side panel similar to the Swipe map?
AndyHenry
Awesome! One last question, from a programming standpoint (which I’m not a programmer), I would assume changing the color of a tab or a side panel is fairly easy?
GregoryL_Azou
Yes. Did you notice in the builder, in settings that you have a 'Theme' configuration?
That's a limited of choices of color but when you download the app, those colors changes can be configured through a configuration file. You would be edit the theme configuration.
