Changing and retaining background color of shortlist left pane tile
2042
06-10-2014 07:56 AM
ScottMoyer
In a shortlist map, I successfully changed the background color of the tile in the left pane in the style.css > ul.tilelist li > background- color. Hovering over a tile turns white as it should, but post-hover it reverts to the default grey. How do I get the custom color to stay after the post-hover?
Scott
MarkCooney
Hi Scott,
Changing the value for the COLOR_DIM variable in the main.js file (~line 10) should do the trick.
-Mark
MarkCooney
Hi Scott,
-Mark
ScottMoyer
Thank you Mark, that did it.
