Change Bullet Text
2910
08-24-2015 11:34 AM
ElaineDennehy__AICP__GISP
Is it possible to change the numbers/text in the ArcGIS Online Hosted story map series - bulleted layout? I'm trying to imitate the Smithsonian bullet text below. I'm afraid using the configurable app is a bit beyond me...
StephenSylvia
Unfortunately you will not be able to do this with the hosted version of the bulleted layout. You would need to download the code, modify the javascript and host the customized version on your own server. The tabbed layout in the Map Series app will allow you to change the text in the tab. It functions the exact same way as the bulleted layout except the tabs are not circles.
StephenSylvia
Nuts - I figured as much.
Thank you!
