Cascade Storymap Jumps to Web Map App
1771
12-06-2018 04:23 PM
RobinMulvey
I have spent a long day troubleshooting this issue with Cascade Builder. The issue arose when two new web map apps were added to the project. A third web map app was already in the project and not causing issues. When the story map is opened and you beginning scrolling through the content, it suddenly jumps to the first of the two maps.
Troubleshooting so far:
In Story Map:
-changed from narrative to immersive style for those two maps, though that was not preferred (didn't fix)
-changed appearance to button enabled from auto enabled (didn't fix)
-when the first map was removed, the story map jumped instead to the second map
In Web App Builder:
-hid/removed splash screen (didn't fix)
-changed from splash to About widget (didn't fix)
-totally rebuilt the web map app by replicating the one working web map app and replaced with the desired web map
-once the rebuild was complete but three of the previous widgets retained, the problem persisted
-next, I removed all widgets (IT WORKED! NO JUMPING!) and next began to add the widgets back one by one
-the first one I added was the legend- IT WORKED! Or, should I say, it worked until I selected for it to be visible upon opening.
Can anyone help? Has anyone had similar problems? Why would the legend set to open with the map create this issue? The other (functioning) web map app in this project also has a widget set to be visible on opening, the summary widget, and this does not cause a problem.
Your help is much appreciated. We are on a tight timeline for this project.
Robin Mulvey
robin.mulvey@usda.gov
Tags (1)
OwenGeo
Esri Notable Contributor
Hi Robin -- Sorry you are having an issue with your Cascade story. I have seen some embedded web pages hijack the focus of the page and cause a Cascade story to jump to their location, although I haven't seen it specifically with Web AppBuilder apps. Some web pages/apps force focus and produce an unwanted experience.
The best Cascade stories don't require the reader to do much interaction with the story content/maps while experiencing the story. Are you able to use a simple web map in your story to avoid embedding more sophisticated mapping apps with more buttons and features that distract from your narrative (and in this case are causing other issues as well)? You can always provide a link out to the full app (which will open in a new tab) so interested readers can do more exploring.
Owen Evans
RobinMulvey
Update: it seems that several widgets, when set to appear on opening, create the same problem. The problem occurred with the Legend and About widgets, but apparently doesn't happen with the Summary widget.
OwenGeo
Owen Evans
