Can You Hook Into Map Series StoryMap Webmap Change Event?
522
10-09-2019 08:27 AM
PatrickMcKinney1
I am working on developing a JavaScript solution to add the alt attribute to images in map popups. Using the events listed in this repo's readme, I cannot get consistent results when changing between webmaps. I have tried the code in different topic.subscribe sections within the custom-scripts.js file.
Is there an event that fires when the webmaps change? I'll provide my sample code below. Any help is greatly appreciated:
let webmap = app.map;
webmap.on('click', function() {
        // only execute code if a popup is displayed on click
        if (webmap.infoWindow.isShowing) {
            // img elements within the feature popup
            let popupImage = document.querySelectorAll('div.image > img')[0];
            if (typeof popupImage !== 'undefined') {
               // popup title - bridge name
               let bridgeNameElement = document.querySelectorAll('div.esriViewPopup > div.mainSection > div.header')[0].innerHTML;
                // add alt attribute using bridge's name
               popupImage.setAttribute('alt', bridgeNameElement);// || 'some string'
