can you change out the image on the front page of your story map
3862
8
10-17-2017 02:35 PM
jeandavis1
I want to change the picture I have on the front page of my story map and can't figure out how to do it.
RupertEssinger
Esri Alum
In the Story Map Journal Builder, click the Edit button (pencil icon) next to the section you want to change the image for, and then in the dialog that appears, click the Back button at the bottom if it is showing you the Position options for your existing image:
This will take you back to the options for replacing the image:
Rupert
RupertEssinger
Esri Alum
Three questions for you
1) Which Story Map app template? (there are 8)?
2) Which picture? Some of the apps have a cover page, all of the apps have a logo in the header, etc.
3) Where and how are you trying to change the picture so far.?
Rupert
jeandavis1
I am using the journal template.
The picture is on the cover (home) page. I want to replace it with an updated picture. I can’t seem to figure out how to change or update any of the pictures on the main stage of the page.
Thank you!
RupertEssinger
Esri Alum
Rupert
jeandavis1
Rupert, you’re awesome! Thank you so much. I didn’t think about hitting the back button.
RupertEssinger
Esri Alum
No prob. It comes up quite often because that Back button is a bit far down in the UX. As soon as you said Map Journal, I was thinking that might be the issue.
Rupert
jeandavis1
Thanks again. I may keep you as my story book contact if that’s ok with you!
FerdinandQuinones
Hi, Rupert, and thanks for the help. Another issue: Several of my Story
Maps had links to images located in the "public" folder in Dropbox. Dropbox
no longer allows these links directly into the public folder, so several of
my stories are blank. I began correcting them by inserting the images from
my server. Below is an example of the first one I edited. Notice that the
image for section 2 is shown with inaccesible image. But I already
re-entered the new link as shown in the third line as a new page 2. I do
not know or can find out how to delete the first page 2 with the note of
the inaccesible link. Once I find out how to do this I can fix my other
stories that suffer the same problem generated by Dropbox. Please advise
how to delete this line in pink. Thanks
Ferdinand Quinones
RupertEssinger
Esri Alum
Hi Ferdinand, Could you start a new, separate question for this? It make it easier for us to manage and also makes sure that others can see your question.
Rupert
