ADA Accessibility for Cascade Story Maps
1147
09-26-2018 08:38 AM
NancyRoss
I have a Cascade Story Map that I'm being asked to make ADA accessible. I've seen a post showing how to do it for Journal and Map Series, but not Cascade.
OwenGeo
Esri Notable Contributor
Hi Nancy -- See this blog that was updated in June 2018 when we added the ability to add alternative text to media via Cascade Builder.
Owen Evans
OwenGeo
Owen Evans
NancyRoss
Thank you so much!
AndrewBernish__MDOT_
There appears to be a bug in this. I am using several videos for a cascade story map as the 'lead' image. I go to add the alt text for these videos and everything appears to work just fine. After adding the alt text, I click the blue check mark and exit, and save the story map, but whenever I go back into the manage menu, the alt text that I had entered for the video has disappeared and is blank. This only happens for the videos. The images work fine. My story is here: https://maryland.maps.arcgis.com/apps/MapSeries/index.html?appid=bebb1baf10c543da856dbcbaf5e246b3. Please help!
