When I change the size of a polygon, why can't I calculate a new area?
2691
10-30-2015 08:42 AM
Cathina_Gunn_de_Rosas
The title sums it up.
I have some polygons. I did an > Add field >> Calculate area
I edited them and a few became significantly larger.
I added another field, calculated the area ... and I get the same results.
DanPatterson_Retired
Maybe you calculated the coordinates in the units of the data frame or the other way around... you can have unprojected data in a projected frame and vice versa, so you will have to figure what is what
Pieter_Geertvan_den_Beukel
perhaps a few screendumps of the used coordinate systems will help.
Another suggestion: store your data in a (file) geodatabase instead of using shapefiles. In a geodatabase the area is auto-calculated
