Was wondering if anyone could walk me through this workflow problem I'm having. I'm relatively new to the Arc Pro world.
I have a series of polygon files (50+ layers representing various geologic rock units); the recommended discrete color assignments are embedded in the attribute table of each layer in a single text field that contains the suggested rgb code for the various rock type. Each layer can have over 100 unique units with up to 30 different color assignments - so manually inputting these color definitions would be extremely time consuming.
Reviewing the help notes, sounds like I should be able to do this by working through the
