Polygon Boundary Symbology
2653
7
01-03-2017 05:40 PM
AndrewBahnsen
Without editing, converting, creating more data or using colour fill is it possible to display the boundaries of adjacent polygons with different coloured lines based on an attribute by using a display offset or something like that i.e.
If colour fill was to be used:
 If colour fill were to be used.
The target condition although was done using graphics and fudging:
Seems like a simple enough request, hope someone has a solution.
Cheers
AbdullahAnter
Honored Contributor
I think you need Representation.
create all layers in Geodatabase and make Representation.
the following link may be help you:
http://desktop.arcgis.com/en/arcmap/latest/map/working-with-layers/a-quick-tour-of-cartographic-repr...
AbdullahAnter
Honored Contributor
AndrewBahnsen
Thanks Abdullah, coincidentally I discovered representation last week but no luck. This morning I read more about it and persevered and have come up with a solution so thanks anyway.
Representation its good stuff but I wonder how a geodatabase performs across a WAN when loaded up with it.
Cheers
JoshuaBixby
Can you share your solution for others who may have the same need/issue?
From my experience, accessing any type of geodatabase (enterprise, file, personal) over the WAN is a less-than-good idea.  At a minimum, the performance suffers, and in certain situations I have seen it lead to data corruption.
AndrewBahnsen
I can share it but how do I do that. Do you mean provide more detail than the discussion has.
Regards
Andrew
JoshuaBixby
I may have misread your earlier comment.  I thought you found a solution that didn't involve representations, but if that isn't the case, my mistake.
AndrewBahnsen
Hi just hoping you can answer this query.
I now have a feature class with several representations but when I add it to Arcmap it defaults to the first representation I created. Is it possible to change the default representation.
Regards
Andrew
DanPatterson_Retired
it may be covered somewhere in the help topics Modifying representation properties—Help | ArcGIS Desktop
