How to make a layout background transparent in ArcGIS Pro?
33180
12
01-15-2018 12:50 PM
LucasMostyn2
I cannot make my layout have a transparent background? is it possible?
thank you,
lucas
Tags (3)
VojtěchBlažek
Hello,
I have same problem in 2.9.
Map frame is set to no color, Background in map properities is also witn no color, but in layout appears white. In exported layout is everything OK.
It is really annoing
Please do someone from Esri something 🙂
AlfredBaldenweck
MVP Regular Contributor
The trick is to clip the map to whatever features you're using.
For some reason the map frame will assume you want white, even if you set that map's background color to something else.
DanielSalinas
export layout
file type: PNG
check: transparent background
color depth: 32-bit with Alpha
