How do I label the TOP of a label callout box?
400
04-21-2018 12:20 PM
DavidThomas2
Hello. I am trying to create callout boxes with labels that break the top of the callout box and have a label inside the box as well. I have spent hours trying to execute this, but simply cannot get it to work. I am using 10.4. I can get the text inside the box well enough, but the text on top is my issue. I have attached a sample label. If anyone has any suggestion I would appreciate it.
DT
Tags (3)
AdrianWelsh
MVP Honored Contributor
David,
I am guessing that you will have to customize a label like that, and what I mean is, outside of ArcMap and bring it in as a graphic. But, I am not certain. I'm interested in seeing what others have to say.
Out of curiosity, can you change the top margin of the callout box to a negative number?
