ArcPro Symbology - Graduated color classes no going to minimum
389
10-25-2019 09:21 AM
DanielMeaney
I have imported colors for a Manual Interval graduated color symbology. I've used using both an ArcMap LYR file and referenced an existing layer in  my Pro document, but the lowest range does not adjust to the new minimum value.  There seems to be no way to extend the minimum for the new range of values.
When importing the symbology, I've tried all the options under "Update Symbology Ranges by Data", with no affect on the minimum range.  Seems to be more a problem with modifying symbology, regardless of the import method.
