z-index issues with arcgis-home, arcgis-zoom and the like v4.34
309
11-05-2025 07:31 AM
DeanWilson
I'm working with the calcite components and narrowed my issue to this.  When I use:
<script src="https://js.arcgis.com/4.34/"></script>
<script type="module" src="https://js.arcgis.com/4.34/map-components"></script>
I get this (notice arcgis-home and arcgis-zoom is z-indexed ABOVE the popup):
but when I use:
<link rel="stylesheet" href="https://js.arcgis.com/4.33/esri/themes/dark/main.css" />
  <script src="https://js.arcgis.com/4.33/"></script>
  <script type="module" src="https://js.arcgis.com/4.33/map-components"></script>
I get this (normal z-index on the components.  The popup hides them.):
Any thoughts on a fix for this?
I'm going to sit on 4.33 until this gets resolved because it introduced a bug in my responsive mobile application.
KellyHutchins
Esri Notable Contributor
If you setup your app to use the beta popup component in 4.34 the popup will sit above the other components. https://developers.arcgis.com/javascript/latest/sample-code/intro-popup/
DeanWilson
Thanks for the quick reply @KellyHutchins !
Well I have all of my popup stuff built into my webmaps right now, and with that still being beta, I really don't want to have that in a production application right now.  I do like the fact that the dev team over there is using shadow dom css so the external sheet isn't needed in 4.34 though.  But I suppose I'll just wait for 4.35 (or I guess 5.0) to make the jump.  Any ideas on timing for that?
Thanks!
DitwanDPrice
Version 5.0 is scheduled for release in February 2026. For more details about semantic versioning and the release plan, see the blog post linked here.
