use of custom icon
1082
04-29-2022 11:53 AM
LefterisKoumis
Regular Contributor II
I understand that Calcite has a library of icons to use, however, they don't have the ones I need. I found some under the meridian library however, their use is limited to Esri Partners and it can be accessed only through the Esri partner community.
I would like to use icon only button with an image from a local file. I can use css along with the calcite-button, but I need to remove the outline from the calcite button and make my image to fit inside the button.
BenElan
I suggest using calcite-action. You can add your own image in the default slot. Here is a codepen:
https://codepen.io/benesri/pen/yLvBwNN?editors=1010
