Input Label-Text and Margins
420
10-07-2025 11:18 PM
DavidJantz
The new labels for inputs is excellent. However, this seems to remove the spacing between inputs, particularly the margin-block-end of var(--calcite-label-margin-bottom, .75rem) from using calcite-label. Is this expected behavior?
Example showing difference in default margins between using label-text and calcite-label:
https://codepen.io/David-Jantz/pen/GgomKPP
DitwanDPrice
Hey David, great catch! 👀 We actually have an open issue that will address this: #12450.
In the meantime, you can achieve the same bottom margin spacing by adding a bit of custom CSS here’s an example (CodePen)
