Disable/Remove CalciteCombo item selection icon (React)
890
05-01-2025 11:19 AM
Labels (3)
RobertAdame
Attempting to find out how, if at all I can disable the icon that appears next to the actual icon of a combolist item. I know part of the Calcite appeal is uniformity, but this feels like something I should be able to disable?
KenBuja
The Combobox component is designed for multiple selections and uses those icon for selections in the multiple-selection mode. Can you use the Select component instead?
RobertAdame
I have tried messing with select as well but it doesnt seem to accept just using an icon instead of text?
Converting the parent CalciteCombobox into CalciteSelect with the children being Calcite Options with each having a CalciteIcon being passed nets me this:
You can see the other 2 icons in the other cells working just fine
<CalciteSelect
                    scale="m"
                    <CalciteOption
                        value="circle"
                        <CalciteIcon scale="s" icon="circle" />
                    </CalciteOption>
                    <CalciteOption
                        value="square"
                        <CalciteIcon scale="s" icon="square" />
                    </CalciteOption>
                    <CalciteOption
                        value="triangle"
                        <CalciteIcon scale="s" icon="triangle" />
                    </CalciteOption>
                    <CalciteOption
                        value="diamond"
                        <CalciteIcon scale="s" icon="diamond" />
                    </CalciteOption>
                    <CalciteOption
                        value="x"
                        <CalciteIcon scale="s" icon="x" />
                    </CalciteOption>
                </CalciteSelect>
