content-behind coexistence with search and zoom components.
280
06-24-2025 02:45 PM
LefterisKoumis
I'm using calcite-shell with the content-behind property to enable display-mode: float, which allows the end panel to have an adjustable height.
However, with the introduction of components in ArcGIS API for JavaScript 4.32, I noticed that enabling content-behind causes the <arcgis-zoom> component to disappear, and the <arcgis-search> component aligns directly against the action bar without spacing.
Below is a demo illustrating the visual difference in the <arcgis-search> and <arcgis-zoom> components when content-behind is enabled versus disabled.
https://codepen.io/lkoumis1/pen/yyywrvG?editors=1010
@KittyHurley
MattDriscoll
MattDriscoll
LefterisKoumis
Thank you @MattDriscoll . It works.
I just updated the references to the new newer version of ArcGIS JS API from 4.32 to 4.33 and it cannot display the map anymore with the error "
#spatialReference" "no spatial reference could be derived from the currently added map layers"
All I did was to change the JS version. Why the error? As you can see I still use AMD to declare my feature layer. Will AMD go away in the near future and use only ES modules?
Thank you.
MattDriscoll
Hi @LefterisKoumis It looks like there are multiple scripts still pointing to 4.32 in the settings of that codepen.  Under the HTML => stuff for head.
I think once that is cleaned up it should work.
