Hi all.
I'm using calcite-components@v1.0.0-beta.59
I like the type ahead capability of a combobox but have noticed that when it's used within a modal, the combobox items do not fully display. They are covered by the modal. If I use a select instead, the select list displays on top of the modal.
I attached two pics for reference.
Any ideas about how to render the combox items on top of the modal?
Thanks!
Rob
Hi @RobStauder,
Sorry for the belated reply. I logged an bug for this issue, I'll let you know once it is resolved.
https://github.com/Esri/calcite-components/issues/3099
Ben
Thanks Ben.
I'm still experiencing this using the React library. Is there an option I'm missing?
Combobox needs the overlayPositioning property set to "fixed", similar to https://codepen.io/geospatialem/pen/QWJVZEJ. If your use case varies from the Codepen, could you put together a Code Sandbox for us to troubleshoot?
