Automatically convert CAD drwaings to Geodatabase
2215
8
07-11-2022 02:56 AM
HJSchneidt
Hi, I´m astonished that the ability to automatically convert CAD drawings to geodatabase in Pro 3.0. has been removed. Why? It makes my everyday work unnecessary more complicated.
Or do I miss something here?
MichaelVolz
Esteemed Contributor
Can you please clarify what your workflow was in previous Pro versions where you feel this functionality has been removed?
HJSchneidt
It seems that the CAD option has been removed in 3.0
Here is the 2.8 equivalent which I can't find anymore. https://pro.arcgis.com/en/pro-app/2.8/help/data/cad/cad-options.htm
MichaelVolz
Can someone from ESRI answer if there is an alternate workflow in ArcGIS Pro 3.0 that has not been indicated in the ArcGIS Pro road map?  I will be working on a project where this capability is needed and this would keep the project at ArcGIS Pro 2.9 instead of upgrading to ArcGIS Pro 3.0.
BrianBaldwin
@Anonymous User - Wasn't sure who else to direct this to - any comments/ideas?
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
CiciXiao
You can use the GP tool - CAD to Geodatabase - to complete the same workflow of converting CAD files to a geodatabase
jtermaaten
We noticed the same behavior, sadly. After some discussion and research with Esri, an enhancement request has been created to reintroduce this in a new version. It is connected to the bug ENH-000153059: ArcGIS Pro 3.0 does not have the option "On adding new layer to map, convert CAD feature class to project geodatabase"
AdrianWelsh
MVP Honored Contributor
HJSchneidt
Hope it's soon back as an conversion option on Pro startup.
