Autocad 2018 incompatible with with ArcGIS Desktop 10.5?
11768
17
06-09-2017 09:19 AM
MandyCostley
Does anyone have any experience with Autocad 2018? The latest release doesn't seem to be compatible with ArcMap Desktop 10.5. I've tried running the CAD to GDB tool and adding the files in the table contents - both are coming up blank, when they would work fine with the previous Autocad 2017.
I'm not very familiar with Autocad, but the drawing comes up with no issues in the cad environment.
GaryMartin1
Cliff,
AutoCAD doesn't convert your drawings when you install it.  At least not in Windows. Your drawings are still in their original version until you open and save them in AutoCAD 2018. You can change a variable so that each time you save, the drawings will be saved to an earlier version of your choice.
To set the default file save format in the AutoCAD Options:
  1. Type OPTIONS on the AutoCAD command line.
  2. In the Options dialog, go to the "Open and Save" tab.
  3. In the "File Save" > "Save as" drop-down menu, set the desired file format.
  4. Click OK.
Hope this helps.  I wouldn't expect any help form AutoCAD, this is an ESRI issue.
JakubSisak
Honored Contributor
Short term solution without AutoCAD - install DWG True View (an official Autodesk DWG viewer), convert the file to 2013 version. This will also handle all X-REFs and other references and downgrade all to whathever older version you choose.  Backup your original 2018 DWG before converting.
JayGeisen
Does anyone know if AutoCAD 2018 files can be read in 10.6?
AdrianWelsh
MVP Honored Contributor
Jay,
I am not sure. I am guessing not yet? The only way to know is to try. Either way, there is a workaround as stated above. Either:
Or
I have found that saving your drawings to an older version (2013) will allow you to add them normally without any problem.
JustinConnerWR
The feedback I received from ESRI support is that this can't be registered as a bug since it's a new AutoCAD release, and it isn't supported in 10.6 or Pro (Supported CAD formats in ArcGIS—Help | ArcGIS Desktop ).  They won't prioritize 2018 integration unless they get enough complaints to see it as critical for their users, and ESRI won't release 2018 support as a patch for any existing Desktop version.
JasonDickeson1
So where do we go to lodge a complaint and get this moving up the list?
DanPatterson_Retired
You might have better luck with launching an Idea ArcGIS Ideas
JustinConnerWR
