Hi all,I have checked the API reference and the Concepts reference for the Community Analyst API, but I can't see anything that describes the geoprocessing routine that generates the reports. In order to use the API, I need to know what assumptions are being made. For example, in this sample:http://help.arcgis.com/en/communityanalyst/apis/flex/samples/index.html?sample=SummaryReportsare the values merely a summary of the census geographies that fall under the selected polygon, or is a clip taking place? If the latter, is there an assumption that population is regular across the entire census polygon, or is population apportioned based on other variables, e.g., land use. I suspect I'm just missing a key reference that documents how BA works - can someone please point me in the right direction???TIA,Julie
Tony,Thanks for the response! It sounds like you have a defensible approach, but I still would like to know a bit more. Every analytical result has caveats and pitfalls, and it's difficult to really know what decisions can be made based on data that isn't qualified by a clear understanding of the algorithm that produced it. I know that dasymetric mapping comes in many flavors, especially depending on the inputs you select for your interpolation. Do you have a whitepaper that summarizes the techniques you're using? Perhaps, at least some peer reviewed articles referencing the key components of your algorithm(s)? Thanks again!Julie
Julie,You find the below link to the Business Analyst 10.1 Desktop online Help useful as it details how the software summarizes data. There are several methods that allow to decide how data is summarized spatially. I believe BAO uses a method which is like the Hybrid that is detailed but I find the section on block apportionment vs. cascading to me the most informative.http://resources.arcgis.com/en/help/main/10.1/#/Data_tab/000z000000v7000000/Regards,Jason R.
I am writing a fact sheet to make folks at my university aware of the availability of Community Analyst. I would like to be able to give them a definitive answer as to how data is apportioned for non-standard areas (polygons). The answers in this thread point to methods outlined for Business Analyst Desktop (block apportionment, cascading centroid, and hybrid) in ArcGIS Destop 10.x Help. However, I do not see a definitive answer in this thread as to whether these are the same exact methods used in Community Analyst. Can anyone suggest where I could get that answer? Thanks
Thanks much Jason. Very helpful. I have another question. The following Esri web page seems to indicate that Community Analyst Standard Plus currently provides access to 12,764 variables: http://www.esri.com/software/arcgis/community-analyst/variables. Is that right?Also, when I sum up the quantities that appear alongside the names of each dataset (or data category) on the left of the page, the total is 30,595. If these quantities indicate the number of variables in each dataset (or data category), then am I right in assuming that some variables are being "double counted"? I.e., whoever created the list decided that particular variables could be classified in various data categories? Thanks
Again, thanks for you help Jason. (another question:)).Based on what I have read, it seems apparent that USPS ZIP codes are used as a standard geography for summarizing data in Community Analyst. NOT ZIP Code Tabulation Areas (ZCTAs). But I want to be sure that is the case. ZIP Codes or ZCTAs? (If ZIP Codes - how often does Esri update its data summaries/tabulations?)Thanks
Bob,Community Analyst just uses residential delivery zip codes (area/polygon zips) and does not use ZCTAs. ZIP code boundaries come from the NAVTEQ Q4 2011 release for the Esri 2012/2017 data update. Each time there is a new Esri data release there will be a newer zip code vintage.Regards,Jason R.
Thanks Again, Jason. I have been diving deep into Community Analyst and questions keep coming up.I created a 3 mile ring around my home address in Community Analyst Online using "Find Location." I then created a 3 mile ring around my home address in ArcGIS 10.1 (spatial reference WGS_1984_Web_Mercator_Auxiliary_Sphere) using the Business Analyst Evaluate Site tool and uploaded (imported) the shapefile to Community Analyst. The radius of the "3 mile" ring created on the desktop is slightly smaller than that created in CA online, and the reports generated by each are different. Is this a spatial reference issue?
