Downloading Business Analyst Data
2015
10-03-2016 07:22 AM
AdamStokes
Whenever I go to download Esri Business Analyst Data (currently 2015,) it gets about 2.5 of the 10 gb through and then simply stops. It's happened over 5 times. My connection is fine and it always stops around the same point. Is there anyway to fix this?
RakeshSinha
Hi Adam,
It seems like you're downloading the data directly through the browser download and not using the 'Esri Download Manager'. Kindly try using the Esri Download Manager and see if you come across the same issue.
I hope this helps!
Rakesh
